I'm working with a series of 3D sketches. Some sketches must remain visible as reference. While creating the sketches, the dimension call-outs grow too distracting from the linear sketches. Is it possible to hide, or toggle off/on the dimensions while leaving the sketch geometry visible?
Solved by ampster402. Go to Solution.
Aha, that was the option I was searching for.
1. Right click the sketch in the feature manager
2. Select Dimension Visiblity
I'm curious if I can create a short-cut key to toggle the dimension on/off? Is it possible to create a custom keyboard key?
I am sure you can find or make a macro to do this this way it does it to all sketches.
