Inventor Forum
Help - How can I select and hide a surfaces or bodies in the workspace?
6 REPLIES 6
Justin_DeSilva
2651 Views, 6 Replies
I understand how to select and hide surfaces and bodies using the model tree, but this isn't useful when my part has 50+ surfaces and solids and I'm forced to hover over each surface or body until the surface or body I want to hide is highlighted. This is possible using Soildworks but why not Inventor?
6 REPLIES 6
JDMather
in reply to: Justin_DeSilva
Don't you have a folder at the top of the browser that says Surface Bodies?
Can't you right click on the folder and unselect Visibilty?
How is this different than SWx?
Can  you roll up the EOP and attach the file here?
Justin_DeSilva
in reply to: JDMather
I can select and hide both sufaces and solids in the manager tree folders, but what I'd like to do is select a surface or solid in the viewport, right click, and select hide.
JDMather
Shift RMB
Change your selection filter to Bodies.
Justin_DeSilva
Can you tell me where the selection filter option is?
I understand now. Hold shift, then right click, then select Select Bodies.
Sorry everyone, for some reason I was not able to take a screen capture.
Thanks JD.
JDMather
There is also an icon for setting selection filters in the upper left area of the screen.
