M. Peppel-
I was wondring if you still have the helicoil files? I was looking at getting both the inch coarse and the inch fine.
Here's my thread xls. Copy the helicoil sheets to yours.
No guarantee on accuracy, if it's important double check it.
I have just found the .xls file with helicoils. I have copied it but I do not get correct information. When I select a hole from the pulldown inside Inventor (2013 BTW) it says it is a 1/4-20 Helicoil but when I add a hole note on the drawing it only refers to 1/4-20 thread - no helicoil note.
The metric file works as expected. Any idea as to why?
Hello Matthias,
Can you send me an Excel sheet with the metric helicoil coarse (if not asking to much: also the metric fine)
thanks
Stefan
