Hi
i have set up my hatches to set specific hatching to specific materials. How or where can set this to happen by default? At the minute, i have to hatch then right click the hatches and select 'By Material' which is getting a little tedious 🙂
i couldnt find anything in hte styles editor...
Nigel
Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
Hi nmjshaw150,
You can do this in your Standard. On the Manage tab, click Styles and Standards tab > Styles Editor button > Expand the Standard node and then click the Material Hatch Pattern Defaults tab.
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-E5B1FB27-5ACA-437E-857F-9C0C594A3023
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-1D4AD554-39D3-4C8F-A184-2F23D207AD34
I hope this helps.
Curtis
Hi
thanks for the reply. yes i have done that part already. i would like it to be default instead of needing to do this-
can it set 'By Material' as standard? i cant find a setting in the styles editor
Nigel
Nacho
Hi
The Style Library manager confuses me if im absolutely honest. When I go to the tool-
i am only presented with 2 list boxes. there are no options to set or edit my style library so i do this independently within each environment (Part, Assembly, Drawing) as they all have different options. Unless i am not using the right tool....
Nacho
