Inventor General
Distinguished Contributor
Message 1 of 5 (938 Views)
Hatch Pattern per Material????
938 Views, 4 Replies
10-03-2012 09:09 AM
Is it possible to assign hatch patterns for material styles? I need IV13 to draw Ansi32 for steel and Ansi31 for Aluminum automatically.
PaulMunford
Message 2 of 5 (921 Views)
Re: Hatch Pattern per Material????
10-03-2012 12:46 PM in reply to: mohandis2
Hatch patterns can be assigned per material in the styles manager.
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
Valued Contributor
Mark.Downes
Message 3 of 5 (900 Views)
10-04-2012 01:30 AM in reply to: PaulMunford
Good morning Paul,
I would like to assign hatch patterns to certain materials too.
I have looked at the styles tab (part & drawing) and can't seem to
find the hatch pattern style.
Any help with setups to speed up the drawing process would be most
appreciated. On this note, I can find most things by trial and error
(poke it with the pointy end of a stick and see what happens)
But a "Did you know this" information would be well received by all
Many thanks
Mark
Message 4 of 5 (882 Views)
10-04-2012 07:02 AM in reply to: mohandis2
Thanks for the response,
Can we do the same thing for the layers and line weight?
E.g: layer called "aluminum" for aluminum, and so on
PaulMunford
Message 5 of 5 (837 Views)
11-01-2012 12:56 AM in reply to: Mark.Downes
Hi Mark, sorry for the delayed response...
The hatch settings can be found by opening a drawing file, opening the Style and standard editor and clicking on the 'Material and hatch pattern defaults' tab.
This is where you can add your standard materials, and map them to your standard hatch patterns. Click on the 'other...' button to get more hatch patterns or load in hatch patterns from an AutoCAD .PAT file.
Mohandis - Layer properties are found in the 'Layers' node of the tree. Layers in Inventor aren't related to materials, they are related to features so there is no easy way of mapping the two. You can do it retrospectively using iLogic.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
