Inventor Forum
HTD timing belts
2 REPLIES 2
ScottSwens
4570 Views, 2 Replies
HTD timing belts
Does anyone know where I can configure a HTD timing drive with a 3mm pitch, 140 tooth, 9mm wide timing belt using a 34 tooth pulley to a 48 tooth pulley.
I have the pulleys, I am just trying to get the timing belt.
I don't think the drive belt tool has this style belt in it.
I am running IV2011.
2 REPLIES 2
mercerc
in reply to: ScottSwens
Since we don't model the actual timeing belt you may want two use one that is close and use the existing pulley option. You can then rename the parts if you like.
You may also want to use the link below to add that set of as a wish list item.
Charlie M
Inventor Product Support Specialist
amattos
A very late reply...
Back in 2009 I had the same issues and I did some editing in the belts and pulleys tables and I was able to use the Design Accelerator to layout (parts only, no calculations) the 5M, 8M, 14m and 20M pitch timing belts.
The following link is for my post at the time with attachement and instructions...check all 3 entries
http://forums.autodesk.com/t5/Autodesk-Inventor/HPT-sprocket/m-p/2357571/highlight/true#M317902
There are attached files that worked at that time with Inventor 11, 2008 and 2009.
Golden rule: Please backup the original files.  Use this information at your own risk...
