Edit the .sat file in Notepad. 3rd line, it says 25.3999999999999999999...,
right? Change just that number to 1.00000 (this sets the translation scale). If
it says 1.000000000000,
Dave Jacquemotte
Automation Designer
www.autoconcorp.com
"DonA" wrote in message news:f17c479.-1@WebX.maYIadrTaRb...
> This seems like it should be sooooo simple, but has got me perplexed.
> I have a mold assembly that was sent to me as a ".dwg" file. I clicked on it
in Explorer and it opened up in Mechanical Desktop just fine. I should mention
that I know nothing about Mechanical Desktop... nor do I care to. Anyway I
selected FILE>EXPORT>DESKTOP ACIS, gave it a file name, highlited all the
features and saved... This all went fine.
> I then opened the ACIS (.sat) file in Inventor, this also went fine, I got the
assembly and all the associated parts. BUT when I started working with the
Inventor files I noticed that "actual" size of everything was too small...
everything was in mm size. I switched to Inches and that went OK BUT the
"actual" size was still wrong. All I was able to do was change mm to Inch, but
could never change the "actual" size of the part/s. As an example the part in
Mechanical Desktop is 8 inches long, but in Inventor it came in as 8mm long, or
0.315 when I switched to inches.
> For the life of me I cannot figure out how/where to get Inventor to bring the
part in as the correct size (8").
> Interestingly, I saved the same drawing from "Mechanical" as a STEP ".stp"
file. When I brought the .stp file into Inventor, the size was correct (8"), but
all I had was a "dumb solid" (all of the assembly components were bunched
together in one big part).
> Again... seems like this should be so simple. ANYONE... what am I doing
wrong... or better yet how do I do it right?
> Appreciate any help.
> Regards and THANKS,
> Don A 🙂
