Inventor General
Valued Contributor
methoni
Message 1 of 4 (134 Views)
HOLE LINE UP
134 Views, 3 Replies
10-04-2013 06:32 AM
I have drawn an assembly of parts and now wish to line up the small hole in the large shell to the projecting pipe,i thought it would be a simple task of using mates (insert aligned) but this does not let me pick on the boundary
of the small hole.
Any suggestions.
JDMather
Message 2 of 4 (123 Views)
Re: HOLE LINE UP
10-04-2013 07:21 AM in reply to: methoni
An assembly file (*.iam) is only a list of hyperlinks to the part files (*.ipt) and a record of assembly constraints (and a bit more).
You must include the part files.
This topic has been covered here many times in the past - a search might turn up the solution.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Valued Contributor
methoni
Message 3 of 4 (107 Views)
Re: HOLE LINE UP
10-04-2013 07:56 AM in reply to: JDMather
JD
This is what I mean, how to line up the large vessel inlet hole to the pipework.
When you say part files do you mean the project or the individual parts that go to make up the assy.
Regards
JDMather
Message 4 of 4 (103 Views)
Re: HOLE LINE UP
10-04-2013 08:08 AM in reply to: methoni
Maybe a pretty picture to illustrate will help.
Note the file size of the assembly *.iam file.  Note the sizes of the part *.ipt files (especially the Arbor_Frame.ipt).
The assembly file is only a list of where to find the part files to put them all together into an assemebly (and how to put them together).
You attached only this - the instructions, (the *.iam file) you did not attach the parts (the *.ipt files) that go with the instructions (the *.iam file), so there is nothing to instruct.  Nothing for us to help you with.  I guess someone could model up some parts as an example or search here to find the previous topics on this problem (the problem is well understood).....
I'm suggesting that you attach the ipt files here.
Someone will show you the solution using your files that you will then be able to apply to any similar problem in the future.
http://forums.autodesk.com/t5/Autodesk-Inventor/The-best-way-to-insert-one-tube-in-another-tube-whic...
Attach assembly shows two different techniques.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
