Inventor General
Forumhelp2012
Message 1 of 2 (63 Views)
Accepted Solution
HELP Loft is showing difficult to follow
63 Views, 1 Replies
10-09-2012 04:18 AM
Hi
I am following the U-Tube exercise called "Emergency Light (Cabinet) volume 1".
I am at time stamp 1 hour 26 minutes, exactly.
In the video they use a Loft command in order to cut a shape out of two sketches numbered 10 & 11.
I have been copying exactly and am having difficulty at this stage of the model.
Is there any reason why I am managing to use the Loft command earlier perfectly but not at this point.
I would appreciate any help from anyone.
Kind regards
A CAD Student.
http://www.youtube.com/watch?v=cBu3UjXG_cM
This is the URL to see what should be happening. The Loft command works here, but when I try it i wont.
Is there anyone that can and will help me please I am in need of help please.
*Expert Elite*
JDMather
Message 2 of 2 (60 Views)
Re: HELP Loft is showing difficult to follow
10-09-2012 04:23 AM in reply to: Forumhelp2012
Why this repost http://forums.autodesk.com/t5/Autodesk-Inventor/Loft-command-not-working-for-a-cut-Any-suggestions/t...
I don't see where you made the changes I suggested in my first response.
It works here fine when I make these suggested changes.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
