Inventor Forum
HELP! Assembly won't open - Unresolved link
5 REPLIES 5
1748 Views, 5 Replies
I'm trying to open my CNC project and I have an assembly in it that will not open.  The file is in the correct location.  I tried to open the assembly directly and it will not open.  So I figure the file must be bad.  I tried the old versions folder and tried to restore it from there.  I had the option to open and not save and it opened.  Then I went back and tried the open and restore.  Again no luck.
I had a part reference problem during my last session.  There was a step file assembly that I had imported into the assembly.  It was a rail with two bearings.  I copied the bearings and added them to the larger assembly.  Then went back to the original file and deleted the bearings.  I noticed that when I went to move the copied bearings I got and error.  I could not move them because there was no reference part.  I saved the part and figured I would go back and fix it later.  Now the part will not open.  I figure that's what caused the issue.
I have a backup copy of the entire project saved before the above errors.  It's on a different drive.  If I try to open it up I get the same unresolved link error.  On top of that, if I open the assembly it will open and the bearings are missing!  How is that possible?  The complete part with all files folders and assemblies are on a separate drive saved months ago and the error is the same.  I'm confused . . . any ideas??
- Allen
Tags (1)
5 REPLIES 5
JDMather
Are you using Projects (*.ipj) or are you using Vault?
blair
Possibly your Projects file, is pointing to different directories and file paths would be the first item that I would look at.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
in reply to: JDMather
I'm using Projects
in reply to: blair
How do I go about checking file paths to be sure it's pointing to the correct location on all files?
blair
Either from the Start Menu: Start>Autodesk>Inventor>Tools>Project Editor or from within Inventor (need to have all files closed). You will need to make sure the Project you are using has it;s work directory point to the directory you are using for all your main files and any Library & CC directories are correct.
Delta Tau Chi ΔΤΧ
