Inventor General
Message 1 of 10 (8,162 Views)
Getting isometric drawing from pipe model
8162 Views, 9 Replies
04-09-2012 11:46 AM
hi
how can i create an isometric drawing from pipe moldel.
Cadmanto
Message 2 of 10 (8,136 Views)
Re: Getting isometric drawing from pipe model
04-10-2012 04:07 AM in reply to: mmbguide
If you are talking about a view in a drawing you can place your view and while you are in the "Drawing View"
dialog window you can select this command to orientate your model to get the correct view you need.
If this isn't what you are tlaking about then a little more detail would help.
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Message 3 of 10 (8,114 Views)
04-10-2012 09:56 AM in reply to: Cadmanto
please visiti this address
http://labs.autodesk.com/utilities/isometrics/
i want to get out put from inventor like this sample. but how?
Message 4 of 10 (8,077 Views)
04-14-2012 12:41 AM in reply to: mmbguide
please help me that's urgent
Cadmanto
Message 5 of 10 (8,074 Views)
04-14-2012 03:50 AM in reply to: mmbguide
It is hard to see the image, but from what I can make out it looks like all you are trying to do is
make an isometric view.  If that is the case then use the button I showed you in my last posting
and it will then lead you to your model where you will spin the model to the orientation you want.
then when you select done, that orientation will be represented on your drawing.
I couldn't tell if it was exploded.  If you need to do that then you will need to create an .ipn file.
Take a look at this link.
http://forums.autodesk.com/t5/Autodesk-Inventor/Exploded-Views/td-p/3309155
Best Regards,
Scott McFadden
Mark_Flayler
Message 6 of 10 (8,068 Views)
04-14-2012 06:30 AM in reply to: mmbguide
Inventor will export a PCF file, but it will not create the piping isometric (not the same as what some drafters consider an isometric view).
In Inventor you will have to use traditional drafting tools to get your isometric, there is no magic piping ISO button.
Mark Flayler Application Engineer - Manufacturing Solutions Division
IMAGINiT's Manufacturing Solutions Blog:
http://blogs.rand.com/manufacturing/
Mark_Flayler
Message 7 of 10 (8,067 Views)
04-14-2012 06:31 AM in reply to: Mark_Flayler
You can take your PCF to that labs technology though and it will load it up.
Mark_Flayler
Message 8 of 10 (8,066 Views)
04-14-2012 06:35 AM in reply to: Mark_Flayler
Activate a Tube & Pipe Assembly and then use ISOGEN output.
Message 9 of 10 (8,053 Views)
04-14-2012 03:14 PM in reply to: Cadmanto
i mean this kind of output for workshop use
Mark_Flayler
Message 10 of 10 (8,049 Views)
04-14-2012 04:13 PM in reply to: mmbguide
If you tried the PCF output from Inventor and then put it through the Online WS converter and that was not enough for you then you are out of luck.  You will need to use a different program to complete the piping isometrics that you want or do some tedious work in Inventor.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
