Inventor Forum
Getting an Equation from a curve
5 REPLIES 5
254 Views, 5 Replies
Hi there guys,
I don't know if I'm looking in the right software for the solution I need but since inventor can create complex curves from a given formula, I imagie it could help me out. So What I'm looking for is to draw a curve, and get the equation for it. Is it possible?
5 REPLIES 5
admaiora
Not. it's not. i am sorry
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
in reply to: admaiora
Any alternative?
johnsonshiue
Hi! The function you are looking for is like Curve Fit. You can do some search on the web to find some tools. Usually, you might need software specifically for mathematics.
Thanks!
Software Test Engineer
JavaLodge
Excel can do this, and I've used it before.  You'd have to look up some tutorials for it because I can't remember how 😄  It will generate a best fit line based on a set of data and also give you a factor that determines how well the best fit line describes the data.
-Edit-  I just re-read your post and excel can't do exactly what you need, at least not that I know of.  If you could somehow generate data points based off the curve you draw, then excel would be able to do make an equation for that.  It can't go straight from a curve to an equation though.
Slow is good and good is fast.
in reply to: johnsonshiue
If the equation is one of the many options available in Excel, try creating an X-Y scatter plot and fit a trend line.  Under trend line options, one is to display the equation on the chart.
