Is there a way to get a part number on pipes created by the routing tool? It seems that if it's default or custom data, the data gets blanked out on the generated files.
I'm trying to get this to work for a client who uses 2011, and from what I can tell this is still an issue in 2013.
The way we do it, is in the Model Tree, once your route is completed and populated, go to the Model Tree and select the tube, doulble click in the box and rename the tube.
When you do that, it will show up in the BOM as such.
