Inventor Forum
Geometric tolerances -Zero's,comma's and points
3 REPLIES 3
LawrenceFHoughton
489 Views, 3 Replies
Glad I caught this error in Inventor 2013.
See attached
3 REPLIES 3
mercerc
in reply to: LawrenceFHoughton
Thank you for your posting. In reviewing the issue it looks to be related to the dimension style you are using. From my testing it looks like you were using a DIN standard which gives the result you posted in the document. If you use an ANSI dimension style using a point it is not reproducible. But the comma does exhibit the same results.
For the time being you will need to be aware of the dimension style you’re using. I will log this with development.
Once again thank you for bring this to our attention.
Charlie M
Inventor Product Support Specialist
LawrenceFHoughton
in reply to: mercerc
I was using ISO std.
mercerc
Different standard but the results are the same as DIN vs ANSI.
Charlie M
