Inventor General
LawrenceFHoughton
Message 1 of 4 (286 Views)
Geometric tolerances -Zero's,comma's and points
286 Views, 3 Replies
11-28-2012 03:18 PM
Glad I caught this error in Inventor 2013.
See attached
Product Support
mercerc
Message 2 of 4 (233 Views)
Re: Geometric tolerances -Zero's,comma's and points
11-30-2012 05:46 AM in reply to: LawrenceFHoughton
Thank you for your posting. In reviewing the issue it looks to be related to the dimension style you are using. From my testing it looks like you were using a DIN standard which gives the result you posted in the document. If you use an ANSI dimension style using a point it is not reproducible. But the comma does exhibit the same results.
For the time being you will need to be aware of the dimension style you’re using. I will log this with development.
Once again thank you for bring this to our attention.
LawrenceFHoughton
Message 3 of 4 (216 Views)
11-30-2012 08:25 AM in reply to: mercerc
I was using ISO std.
Product Support
mercerc
Message 4 of 4 (213 Views)
11-30-2012 08:33 AM in reply to: LawrenceFHoughton
Different standard but the results are the same as DIN vs ANSI.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
