Inventor Forum
Generating an Elbow on a metal part drawing
4 REPLIES 4
krcastillo
644 Views, 4 Replies
I would like to ask , how to create the elbow part of a metal type  ( actually a  J-shape Bolt  Threaded material)  .
I had finished  the  straight part  by  simply revolving my required profile. then i was to  draw the  elbow part but "sweep" doesnt  work  out
4 REPLIES 4
SBix26
in reply to: krcastillo
Inventor version?  Post the file here.
In what way does Sweep not work out?  Have you tried using the Bend Part tool?
mcgyvr
in reply to: SBix26
If all you want is a "j bolt" you need 2 sketches.. 1 is just a "J" shaped single line sketch.. Then the other sketch is just a circle starting on a plane perpendicular to the first sketch start or end point. Then sweep and voila a "J"
see attached (done with INV 2012)
hagiographa
in reply to: mcgyvr
Is this what you want?
I'm not sure how you'll get the nut past the bend?!
PhilSaw
in reply to: hagiographa
 A Google search on "J Bolts" shows the thread on the straight part only - so no, that isn't what the OP is after.
http://www.google.co.uk/imgres?q=J+BOLT&um=1&hl=en&safe=active&sa=N&biw=1053&bih=494&tbm=isch&tbnid=...
Please click "Accept as Solution" if this response answers your question.
Autodesk Inventor Professional 2012
Windows 7 Professional, 64-bit (Service Pack 1)
Intel(R) Core(TM i7-2600 CPU, Quadro 2000 graphics card, 8G RAM
