Inventor General
New Member
Message 1 of 5 (395 Views)
Generating an Elbow on a metal part drawing
395 Views, 4 Replies
10-17-2012 10:33 PM
I would like to ask , how to create the elbow part of a metal type  ( actually a  J-shape Bolt  Threaded material)  .
I had finished  the  straight part  by  simply revolving my required profile. then i was to  draw the  elbow part but "sweep" doesnt  work  out
*Pro
sbixler
Message 2 of 5 (380 Views)
Re: Generating an Elbow on a metal part drawing
10-18-2012 04:34 AM in reply to: krcastillo
Inventor version?  Post the file here.
In what way does Sweep not work out?  Have you tried using the Bend Part tool?
*Expert Elite*
mcgyvr
Message 3 of 5 (365 Views)
10-18-2012 10:26 AM in reply to: sbixler
If all you want is a "j bolt" you need 2 sketches.. 1 is just a "J" shaped single line sketch.. Then the other sketch is just a circle starting on a plane perpendicular to the first sketch start or end point. Then sweep and voila a "J"
see attached (done with INV 2012)
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2014 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Active Contributor
hagiographa
Message 4 of 5 (330 Views)
10-18-2012 08:46 PM in reply to: mcgyvr
Is this what you want?
I'm not sure how you'll get the nut past the bend?!
Valued Contributor
PhilSaw
Message 5 of 5 (320 Views)
10-19-2012 01:55 AM in reply to: hagiographa
 A Google search on "J Bolts" shows the thread on the straight part only - so no, that isn't what the OP is after.
http://www.google.co.uk/imgres?q=J+BOLT&um=1&hl=en&safe=active&sa=N&biw=1053&bih=494&tbm=isch&tbnid=...
Please click "Accept as Solution" if this response answers your question.
Autodesk Inventor Professional 2012
Windows 7 Professional, 64-bit (Service Pack 1)
Intel(R) Core(TM i7-2600 CPU, Quadro 2000 graphics card, 8G RAM
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
