Inventor General
New Member
R-P-T-0
Message 1 of 2 (168 Views)
GRILL
168 Views, 1 Replies
12-28-2012 03:28 AM
Greetings All.
The part i make is from solid model>The part needs to be in sheet metal.What steps do i use to make as sheet metal part and have option to flatten part.I am learning with Education version
Thanks to any one who can help
Ross
*Expert Elite*
cbenner
Message 2 of 2 (160 Views)
Re: GRILL
12-28-2012 04:04 AM in reply to: R-P-T-0
Hi,  I'm afraid I can't help you with the sheet metal.  But I might make afriendly suggestion that you put sheet metal into your Subject line in some way, so that readers looking through the forums will know right away that this is a sheet metal question.  You are more likely to attract the attention of someone who can help you out.
Good luck!
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
