Inventor Forum
G-Forces in Stress Analysis
5 REPLIES 5
2382 Views, 5 Replies
I am trying to properly stress test a steel aircraft fuselage. I can easily model the estimated weight of the pilot, copilot, etc as loads on the airframe. However, when it comes to simulating a high-G situation, (a load factor of around 7.5 times the force of gravity), I am not sure what to do. On one hand, I can simply multiply the loads on the airframe by the load factor and see if the frame can take it. In most cases, it performs very poorly, (safety factor less than 1). However, if I model all the loads under normal conditions, (normal pilot weight, etc.), then add a gravity load equal to 7.5 G, the airframe performs well. Yet I am not sure if the loads on the airframe, (such as pilot weight), are being adjusted along with the increased gravitational load.
My question is, what is the best way to accurately simulate real world loading for high-G situations? I would a appreciate an experienced opinion on this matter.
5 REPLIES 5
blair
Apply your Gravity (apple icon) along with it's direction vector and change gravity from it's default 1g to the the desired G
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
in reply to: blair
Thank you for your swift response! Just to clarify, so I do not need to increase my applied loads, (which are in place of component weights such as the pilot,copilot, etc.)?
cwhetten
Hi and welcome to the forum!
Increasing the acceleration of gravity in Inventor simulation will only increase the body load of the elements in your model.  It does not also increase external loads of other types.  If you have external forces applied that represent weights, Inventor doesn't know that those are supposed to represent weights.  You will have to increase the magnitude of those loads accordingly.
Cameron Whetten
Inventor 2014
in reply to: cwhetten
Ah ha! I worried that was the case. I will be sure to change both the loads and the gravity vector. Thank you for your response!
rmerlob
I you ever need to do more complex scenarios (ie gravity and acceleration in different directions) I think you should read into the ´´Body Load´´ type load I think this is the actual intended aplication for it.
Sorry I cant give some real insight since I´ve only toyed around with it.
RM
