Haven't seen any in a while though I haven't been on here as much lately either.
Here's a couple FIAT parts we're getting ready to release. First is a Torque Strut (rendered in Showcase) and the 2nd is a WIP Upper Front Strut Mount replacement.
What are you guys/gals working on today?
Solved by cwhetten. Go to Solution.
I realize not all forum members celebrate turkey-day tomorrow, but here is another Friday Picture since today is Friday for me!
The 3D model can be found at this link ( thanks to dan_inv09!)
I know it's not Friday, but this one was fun to play with this morning.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Very similar to the equipment I work on.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Measured off foundations & stringlines. Materials ordered and manufactured while the ramp & block walls were being completed, and upon final measure we learn that the architect had neglected to look at the disabled access codes before sizing up this ramp and it's a bit small... and now there is a chance the builder will have to redo this whole ramp.
I'm sick of having to rework projects because people cut corners knowing full well they are risking compliance of the whole area.
</rant>
I might have posted this a while back, a chassis quickly rendered out.
Time to get into the spirit for the next holiday!
Sadly flooded with work atm, so don't have enough time to make a nicer scene... 😞
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
This a structure that I am working on. Overall height is 107', width at base 47'. Total weight is 261,500 lbs. Made of steel.
Reverse-engineered this bolt-action receiver for a buddy - this probably wins most features I've ever put into a single part!
Rendered by Inventor
