Inventor Forum
Friday Pictures 6-27-'14
15 REPLIES 15
Message 1 of 16
-niels-
847 Views, 15 Replies
Ok, early start on this but i finished this yesterday.
This is the fruit harvesting machine i posted the optional parts for in a previous post.
It was quite a hassle getting this done, it locked up my PC transferring from Inventor to Showcase everytime for some reason.
So i used my old pc, which i could leave alone and work on it without interruption, and after about an hour and a half i finally got a model in Showcase.
Only to find that if i saved it, it didn't open anymore... Smiley Frustrated
After many hour and a half's later, i managed to get it into my Showcase by saving out as an FBX and reimporting in SC2015.
I had some fun trying out the 'backplate' environments, so here's the result! :
and another view
So, what are you all working on?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
15 REPLIES 15
Message 2 of 16
in reply to: -niels-
Just a motor/impeller/volute
Message 3 of 16
riff62
Particle Accelerators... Cant post pics unfortunately.....sorry....I can direct you to our research web page so you can get an idea of what we do... http://www.lepp.cornell.edu/Research/WebHome.html
Message 4 of 16
mrattray
Looks like an electric supercharger.
Mike (not Matt) Rattray
Message 5 of 16
-niels-
in reply to: riff62
Sounds like interesting stuff, for some reason i now want to watch Big Bang Theory episodes 😄
Niels van der Veer
The Netherlands
Message 6 of 16
Mezzanine Crib with Sliding Gate14162 AB Automation Crib Mezzanine Front.jpg14162 AB Automation Crib Mezzanine 1.jpg14162 AB Automation Crib Mezzanine 7.jpg14162 AB Automation Crib Mezzanine - Gate.jpg
Message 8 of 16
blair
in reply to: cbenner
If I showed you, I would have to kill you 🙂
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 9 of 16
jeanchile
Sulphuric Acid Circulation Heater Skid... not so top secret.
Inventor Professional
Message 10 of 16
blair
in reply to: jeanchile
nice Showcase render
Delta Tau Chi ΔΤΧ
Message 11 of 16
wimann
Synyster Custom Guitar. Started it a while ago, just recently found time to finish. I'm in love with how these renderings turned out. Thank you Showcase.
Admitedly, there's still a little modeling to do for this to be 100% but I'm still pretty happy with the renderings.
-Will Mann
Inventor Professional 2020
Vault Professional 2020
AutoCAD Mechanical 2020
Message 12 of 16
-niels-
in reply to: wimann
Very nice, so it's a private project?
Are you building it for real? (Or is it storebought?)
(You may notice i don't know that much about guitars. 😉 )
Niels van der Veer
The Netherlands
Message 13 of 16
wimann
it's alright 🙂 It's a design that's already out there. Made by Schecter. I've bought more than one of these guitars and they're just amazing. So one day, I thought I'd model it up. Then I got busy and had to set it on the back burner for a while and I just recently got around to finishing it.
-Will Mann
Message 14 of 16
cwhetten
in reply to: wimann
Looks fantastic.  Keep up the good work!
Killer paint scheme, too.
Rock on.     \ . . /
Cameron Whetten
Inventor 2014
Message 15 of 16
jeanchile
in reply to: blair
Thanks. I just started to learn how to use that program and they almost took it from me. I'm glad it's back. I've seen a few of your Showcase renders around here that look fantastic. It inspired me to do some research online and the common Showcase comment from a lot of people is that Showcase can produce some nice, quick renders that look okay but only if you "bake" the shadows.
Does anyone here know what "bake the shadows" means?
Message 16 of 16
sam_m
i always thought "baking" was rendering but after a google it looks like it's a pre-rendering process to try and reduce the final rendering time.  I may well be wrong, but it sounds like it's a mini-render that calculates how the shadows would fall in the scene and then adjusts the image/surface texture wrapped around the objects to incorporate the shadows - so there's no need to re-calculate them each time you render.  But, I'm guessing that every time a light is moved or the surface is changed then these would need to be re-calculated, so I'd imagine the time saving is only evident at the end of a project when you have everything in place and are rendering a load of views.
But, I can't understand how this would work with anything moving - each frame of the animation would have different shadows, so is a different texture applied to the object for each frame?  seems crazy...
There's some info in the Showcase forum:
http://forums.autodesk.com/t5/General/Someone-please-explain-baking/td-p/4277252
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
