Inventor General
Valued Contributor
Cool_Breeze_Jr
Message 1 of 5 (196 Views)
Frame generator
196 Views, 4 Replies
10-30-2012 01:19 PM
My skeleton has lost translation with my frame generator and has offset the sketch. I have tried "Edit with Frame Generator" but the peices seem to stay in place.
Chris Biggs
Engineer/CADD Services
New Horizons RV Corp.
2401 Lacey Drive
Junction City, KS 66441
Dell XPS 8300
Intel(R) Core(TM) i7-2600 CPU@3.40GHz
16GB RAM
Win 8.1 Pro
Autodesk Product Design Suite 2014
Product Support
Message 2 of 5 (142 Views)
Re: Frame generator
10-31-2012 04:03 PM in reply to: Cool_Breeze_Jr
You ae more than likely dealing with a corrupted file. Not sure if you have a backup of the assembly and not sure if you can do a replace component on it either as I never tried this. You can try using dethe "task schedular"  and run the file tion utility, choose option "Total Rebuild" and "Compact Model History" and let this run on the assembly file and all files for the project. Try opening the assembly then.
Don
Valued Contributor
Cool_Breeze_Jr
Message 3 of 5 (117 Views)
Re: Frame generator
11-01-2012 05:07 AM in reply to: 4donwan4
Don,
Thanks for the reply, however I am not using any type of vault so these options are not possible. Being that only 2 of us work here we just copy what we need to modify.
Chris Biggs
2401 Lacey Drive
Dell XPS 8300
16GB RAM
Win 8.1 Pro
*Expert Elite*
cbenner
Message 4 of 5 (110 Views)
Re: Frame generator
11-01-2012 06:18 AM in reply to: Cool_Breeze_Jr
Have you tried a "Rebuild All" in Inventor?  Sometimes this works....
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
Valued Contributor
Cool_Breeze_Jr
Message 5 of 5 (100 Views)
Re: Frame generator
11-01-2012 06:48 AM in reply to: cbenner
I tried that with no results. I think the file is corrupt. Thanks for the suggestion though.
Chris Biggs
2401 Lacey Drive
Dell XPS 8300
16GB RAM
Win 8.1 Pro
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
