Inventor General
tuliobarata
Message 1 of 4 (286 Views)
Frame - Notch with offset
286 Views, 3 Replies
10-05-2012 12:58 PM
Hey again guys,
Another question using IV 2013  and Frames.
When i get some frames and need to use the feature NOTCH, is there a way to put one offset on it ? like we can do using MITER ?
The solution we've found here is in every member that we use NOTCH, we enter in the frame part and then use the feature THICKEN/OFFSET, this wey i can get the standard offset of 3mm that we use here for welding.
Or, if there is other easy way instead of NOTCH, to make one frame get to other with offset.
The image below shows what i mean, i need to get this off set in the frames on Z AXIS.
Thanks very much!
Túlio Barata
IV 2013
PaulMunford
Message 2 of 4 (279 Views)
Re: Frame - Notch with offset
10-05-2012 02:01 PM in reply to: tuliobarata
tuliobarata
Message 3 of 4 (240 Views)
10-08-2012 01:56 PM in reply to: PaulMunford
Thanks man!
Well, a good way to solve it with that answer, better than mine when i get many and many frames...
Túlio Barata
IV 2013
PaulMunford
Message 4 of 4 (204 Views)
11-01-2012 12:39 AM in reply to: tuliobarata
No Problem :smileyhappy:
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
