Good day.
I have created a frame using frame generator. I did so by creating a sketch in a (dumb) part outlining where i want the steels to go etc. I then added the steels and some bolted connections etc. i did this back in Jan.
Today i need to edit the frame and have reopened the model to find that the connection between my definition sketch and the 'skeleton' has been lost and the frame is displayed wrong.
Is there a way to reconnect the skeleton and my sketch so i don’t have to redraw the model?
W7 64 xeon X5600 8Gig NAVIDA
Chris
Solved by cbenner. Go to Solution.
Can you post your files, or a screen shot showing the model tree so I can see a little more of your workflow?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Chris TH.
What version are you running?
Are you using Vault at all?
Like Chris B. suggested, seeing an image of your browser would help. I would like to see this sketch in the browser of your assembly. Because that is where is needs to be.
Can you locate this sketch on your local drive?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
thanks for the replies.
Here is am image:
the yellow lines are the sketch (214-24-skl) after isome of its dims have been changed, as you can see the frame hasnt updated to the new sizes.
iv12 sp2
we done use vault, we use meridian.
Try Manage \ Rebuild All
Chris Benner
Not to address the problem, but notice your verticle corner legs are not perfectly verticle, the bottoms seem jaggy as if a sketch is at an angle, is this intentional? I do always ground my sketches now, found out the hard way they can be moved in an assembly if accidently constrain the wrong part. have never had your problem occurr, so don't know the answer, just seeing if the corner legs are supposed to be off from tru verticle or if you just didnt notice.
@Anonymous wrote:Not to address the problem, but notice your verticle corner legs are not perfectly verticle, the bottoms seem jaggy as if a sketch is at an angle, is this intentional? I do always ground my sketches now, found out the hard way they can be moved in an assembly if accidently constrain the wrong part. have never had your problem occurr, so don't know the answer, just seeing if the corner legs are supposed to be off from tru verticle or if you just didnt notice.
Looks like a screen resolution issue to me, the bottom sketch does appear to be constrained and the rest projected from it. View is probably just not sitting right on the corner of the view cube.
Chris Benner
I think that is either a graphics issue or an opticle illusion.
I wonder what happens if the sketch gets edited within the assembly does it update.
With all of this aside, I agree that the rebuild all might help you.
I've seen this before, a "Rebuild All" usually forces the frame to update to the sketch changes. It's really not that uncommon.
Chris Benner
Hi CHRISTH,
I suspect the rebuild all suggestions will help, but in just in case that doesn't do it, see this link:
http://forums.autodesk.com/t5/Autodesk-Inventor/Frame-Generator-Will-not-Update/m-p/3001680#M400589
In particular see the information about the grounded status and the rebuild all.
I hope this helps.
Curtis
I tried Manage -> Rebuild, didn't work. So I restarted my pc, then manage and rebuild all and it worked. So happy!!!!!
