Inventor Forum
Frame Generator error - edge spline intersection
3 REPLIES 3
mallorn
404 Views, 3 Replies
I try to put a frame members (pipes) on an edge created by surface intersection, one of the surfaces was made of spline.
Can you please let me know how to use frame generator in this case?
I was trying with different shapes and it looks like the error is not due to self-crossing. You can try with different radius and frame dimensions of my files.
I'm using Inventor 2014 (ETO Series)
Tomasz Malinowski
3 REPLIES 3
Cadmanto
in reply to: mallorn
Frame Generator works from a skeleton sketch.  How is your FG skeleton sketch interacted with the surface spline?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
mallorn
in reply to: Cadmanto
please check attached files
Tomasz Malinowski
mallorn
Problem is solved in Inventor 2015.
Tomasz Malinowski
