I try to put a frame members (pipes) on an edge created by surface intersection, one of the surfaces was made of spline.
Can you please let me know how to use frame generator in this case?
I was trying with different shapes and it looks like the error is not due to self-crossing. You can try with different radius and frame dimensions of my files.
I'm using Inventor 2014 (ETO Series)
Solved by mallorn. Go to Solution.
Frame Generator works from a skeleton sketch. How is your FG skeleton sketch interacted with the surface spline?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
