Inventor General
karthur1
Message 1 of 6 (197 Views)
Frame Generator, Use existing points
197 Views, 5 Replies
02-16-2014 09:33 PM
I dont use Frame Generator that much, but ran into a situation where I thought it might be useful.  I am needing to add a cross member to my frame, but I dont have a sketch that represents the cross members.  Is there a trick to adding them without having to make a sketch on the plane that they will be on?
In the above view, I need to add some braces where I have the red lines.  Wouldnt it be nice if we could pick points from existing members of the frame work?  I tried that, but could not get that to work.
Kirk
Distinguished Mentor
JoAnn_Hogan
Message 2 of 6 (175 Views)
Re: Frame Generator, Use existing points
02-17-2014 12:37 AM in reply to: karthur1
You would need to create a sketch if the cross member is at a certain angle. Otherwise you can use the 2point option where you select two points where you want your member to be. But the easiest would be to create a part and creating the sketch
Please let me know if this helps
Jo (P.S follow me on twitter @JoAnn_Hogan)
If this post solved your issue please mark as solved and Kudos are always welcome =)
AutoCAD Certified Professional 2014 / Inventor Certified Professional 2014
Active Contributor
ASI_Aaron
Message 3 of 6 (152 Views)
02-17-2014 01:56 PM in reply to: karthur1
Interesting enough, you can select individual points on parts that aren't inserted with the frame generator.
But I was unable to select any other points on the channel members you see in the image.
- Aaron -
Autodesk Product Design Suite Premium 2014 SP1
ASUS G750JX-DB71
Windows 7 Pro
4th Gen Haswell i7-4700HQ
16GB Kingston DDR3 HyperX RAM
NVIDIA GeForce GTX 770M
karthur1
Message 4 of 6 (145 Views)
02-17-2014 02:31 PM in reply to: ASI_Aaron
Aaron,
That's interesting, but all my parts are inserted with FG......
A point is a point is a point......why should it matter if its a FG part or other "normal" part?
Kirk
blair
Message 5 of 6 (139 Views)
02-17-2014 03:00 PM in reply to: karthur1
Done lots with points on different work planes, from point to point on either the same or different planes. Never worked with points on a FG part.
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
JDMather
Message 6 of 6 (134 Views)
02-17-2014 03:39 PM in reply to: karthur1
In the interest of creating a robust assembly - I think I would just buckle down and add to the skeleton file.
http://forums.autodesk.com/t5/Autodesk-Inventor/IS-INVENTOR-REALLY-USEFUL/m-p/1332811/highlight/true...
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
