You might like this video. It's (possibly) a better solution because it groups identical items by stock number and
mass - therefore even a small hole drilled in one part will make it different to other similar section/length parts.
If you choose the correct columns for your "Parts List", you can now show the "number-off" where parts are identical - plus the cut length - plus the total length of stock etc.
This item counting thing is one area of FG that's bugged me since it's creation. Only figured this grouping thing out yesterday
[ Screencast|http://screencast.com/t/NWU4MmNlZ]
The first 40 seconds just demonstrates the problem.
(You would probably leave the renaming of the "Part Number" until the last minute because if you do what I did in the video (Long bits, short bits etc) then you drill one part - the item grouping won't update because it's reading "Long bits" & "Short bits", not stock+mass.)
Peter
