Inventor General
Active Contributor
Message 1 of 2 (192 Views)
Frame Generator Sketch and Plane Visibility
192 Views, 1 Replies
01-09-2013 08:36 AM
I added another extrusion profile to my structural shapes library, using the same method as the others a few years ago.  It works, but the new extrusion now shows up with its profile sketch, start and end planes, and driven dimension visible.  The old stuff doesn't (like I would expect).  I have all planes in the published part turned off, not marked for export, etc., just like in the old ones.  What's going on here?  How do I turn this off?  Inventor 2012 SP2.
When I open the extrusion separately, the work features to not display.  But, the it's also shown as the "default" color not as material.  Why does it default to "default" not "as material" like everything else?
Active Contributor
Message 2 of 2 (187 Views)
Re: Frame Generator Sketch and Plane Visibility
01-09-2013 08:54 AM in reply to: smjanows
Nevermind.  My parts have a defualt as well as master design view.  The old ones only had a master.  I deleted the design view, turn everything off in the master, and viola!
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
