Inventor General
Active Member
Message 1 of 20 (1,781 Views)
Frame Generator Problem
1781 Views, 19 Replies
10-16-2012 04:54 PM
When I try to open the Frame Generator Feature in Autodesk Inventor 2013, the dialog box does not appear and I am unable to create or edit frame members. This was not an issue in the 2012 version that I had installed. Does anyone have an idea what the problem is? Thanks!
-Tyler
Distinguished Contributor
Message 2 of 20 (1,767 Views)
Re: Frame Generator Problem
10-16-2012 07:29 PM in reply to: tyler.chidester
Tyler,
I'm not up to 2013 yet, but in 2012 the shapes are edited and created in the sketch environment then enabled for FG use via the Structural Shapes tool, right?
If you're saying the dialoge box is offscreen then this post has some good suggestions...
http://forums.autodesk.com/t5/Autodesk-Inventor/dual-monitor-issues/m-p/2646647/highlight/true#M3688...
Hope this helps,
Active Member
Message 3 of 20 (1,734 Views)
10-27-2012 12:24 PM in reply to: tyler.chidester
Thank you for your response. I dont think it is a problem on the dialog box appearing off screen. I tried several tricks and I just do not think to dialoge box is showing up at all. Any more suggestions? Thanks.
Tyler
*Expert Elite*
Message 4 of 20 (1,731 Views)
10-27-2012 12:57 PM in reply to: tyler.chidester
Open the Tutorial Files > analyze_frame.iam
Right click Edit the Frame0001
Right click Edit with Frame Generator the  first frame member.
What happens?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Active Member
Message 5 of 20 (1,721 Views)
10-27-2012 01:40 PM in reply to: JDMather
Where do you find that tutorial file?
*Expert Elite*
Message 6 of 20 (1,717 Views)
10-27-2012 02:15 PM in reply to: tyler.chidester
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=16463987#
Valued Contributor
Message 7 of 20 (1,713 Views)
10-27-2012 02:29 PM in reply to: JDMather
JDMather u help to all of the people? or any one u want?
Behzad Meskini
freedom for Iran
Active Member
Message 8 of 20 (1,706 Views)
10-27-2012 03:59 PM in reply to: JDMather
JDMather:
Thank you for your response. I tried what you said and have the same issue. Attached is a screenshot of my problem. as you can see there is no dialoge box in sight. Do you have any idea what the problem could be? Thanks
*Expert Elite*
Message 9 of 20 (1,696 Views)
10-27-2012 06:43 PM in reply to: tyler.chidester
Your screen capture would have been a little more informative if you and first clicked on the Design tab.
Sure looks like you are in Frame Generator edit mode but the dialog box is somewhere off-screen.
Are you or have you ever used dual monitors with this box?
*Expert Elite*
Message 10 of 20 (1,691 Views)
10-27-2012 06:51 PM in reply to: bms953
I answer the easy questions if I think I know the answer.
About the only things I know are - "Sketch1 isn't constrained" and "an iam without ipt files is useless".  :smileytongue:
If you stay here a while you will see that I have copied those two responses here around 19,000 times.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
