Hello All
I keep getting Instabilty of node errors in my Frame Generator. Specifically type 3 at node 62 in direction RY. I am new to FG results seem resonable just can't get past this error. I tried deleting the member and inserting a new one in its place. The error then goes to another node?
The application is a steel box frame being lifted by a crane, FWIW.
Also, a side question, when you create specical parts for FG and post them from Iparts, where do they go? I need to go back in and alter some properties.
Bill
Hmm, you should mention that this problem is in Frame Analysis, not frame generator. You'll get a different group of people looking at your question.
I may be able to help with part 2, but I've never done frmae analysis.
If you publish iparts for use with Frame Generator, they go into the Content Center. You can make adjustments or add to the family table easily enough. If you need to change something about the part itself, that's a bit more complex... let me know if that's what you needed. Metadata you should be able to work with in the Content Center. Find the item in question in your Content Center Editor, right click and select Family table.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
