Inventor Forum
Frame Generator BSI standard
1 REPLY 1
DaveyL
508 Views, 1 Reply
Dear all,
I created a frame using 150 x 75 BS4 channel section in 2011/12 (can't remember which) however it was created before the BOM length fix (all lengths stated are not necessarily the lengths of the beams). In order to fix this I need to redraw the frame, which is fair enough, however I am unable to find the BSI standard channel section. Infact, BSI has seemed to vanish from my library completely, I can not even place a component from the BSI library.
I have had a look around the C:/Programdata/autodesk/inventor2011(or 12 or 13)/contenetcentre/libraries and have found parker, gost, DIN etc but no BSI. Can anyone tell me what is going on? I know there will probably be a good explanation for this but I can not find anything about it.
FYI I have not used the frame generator/place component in 2013 yet so no idea if this was from install or not.
Cheers,
Dave
Tags (3)
1 REPLY 1
DaveyL
in reply to: DaveyL
Bump
