Inventor Forum
Found a solution for Huge .Step File Sizes
3 REPLIES 3
DeerSpotter
7396 Views, 3 Replies
1. open .step
2. save as .ipt (i only did this as .ipt might work for .iam)
3. save as catpart
4. start new part
5. import catpart
6. delete new sketch and translation report.
7. save as .ipt
8. convert .ipt to sheet metal.
9. right click on folded metal
10. copy.
11. Go to IExport (expect error)
12. Right click Flat pattern.
13. Save copy as .sat
14. open .sat seperatly.
15. save .ipt after cleaning up feature tree of unwanted new sketch and translation report.
16. Host a party because part file size is significantly smaller.
i wish someone could write code for this 😕
(using inventor 2010 / routing)
Image and video hosting by TinyPic
See My LinkedIn Profile
Tags (2)
3 REPLIES 3
JDMather
in reply to: DeerSpotter
Post example file to be used to walk through these steps to verify your solution.
(post your end solution file as well)
DeerSpotter
in reply to: JDMather
since i cant share any company files, can you provide me with an example and ill post up the shrunk step file in .ipt format.
DeerSpotter
But as a little something:
a 66,524kb file just between CATPart conversion/translation and back to part got me to 56,692kb
and no details were removed.
