Inventor Forum
Folding in sheet metal
4 REPLIES 4
1097 Views, 4 Replies
Hello guys,
I am facing aproblem regarding folding in sheet metal. Below I attach the drawing (.ipt) file. Initially I have 1.5 mm in thickness, and I can do folding perfectly. But when I change the thickness to 2 mm, the folding went wrongly. You can refer to the image that I attached.
Then what I do is I delete all the fold, change the thickness to 2 mm, and redo the fold, but it still went wrong.
Any pro guys please help me, and thank you for your help.
4 REPLIES 4
If i am not wrong, the Hole & small gap resisting for Fold to happen. better you do those holes& that cut after fold creation.
Kiran
Thanks for replying. I understand that the small gap could be culprit. After I follow your instruction, how to do the folding of the cut area tu go down 90 degrees?
JDMather
Wouldn't it be a lot easier (no calculations) to model in the finished form rather than folding a flat sheet?
Aren't the finished dimensions the controlling dimensions?
chad38
I'm not sure why you don't model this as a finished, bent part, then make a flat?? Even if all the customer has is a flat to give you, you'd be better off figuring out the formed dims one time because if the part gets revised, much easier to make the modifications.
HP Z420 Workstation
Intel Xeon CPU E5-1603 0 @ 2.80 GHz 2.80 GHz
12.0 GB RAM
Windows 7 Professional 64 Bit
3D Connexion Space Pilot
Solid Edge ST9 MP1
Inventor Professional 2015
Autocad 2015
SolidWorks 2015
