Inventor Forum
Fold/Unfold
1 REPLY 1
methoni
2958 Views, 1 Reply
Fold/Unfold
Having created what i call a diffuser (please see attachment) i now wish to provide a flat drilling template .idw for use
by the sheet metal fabricators.
When i unfold the .ipt part and create the .idw drawing thats fine the problem is when i refold the ipt part the .idw also reverts back to its folded shape,is there a way to stop this from happening, should i rename the unfolded part,would this be a solution.Perhaps if i was to copy and rename the parts just to create the manufacturing drawing ? by doing this
all association with the original part is then lost,perhaps not the best approach.
I am sure there must be a solution to create develoment parts purely for the use of manufacture ,still retaining the original link. Am i over complicating the issue !
System i am using is inventor professional 2013.
Any suggestions would be appreciated
1 REPLY 1
CCarreiras
in reply to: methoni
Hi!
You're complicating things.
Refold and finish the part, then use "go to flat pattern" to have the flat pattern. (Fig 1) . Save the file.
Open the idw or dwg and, when you are placing the part, choose flat pattern. (Fig 2)
You can also configure a dxf for cutting machines using in the flat pattern enviroment the "save copy as"(Fig3)
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
