Inventor General
sp1n1mbus
Message 1 of 7 (298 Views)
Flexible constraints for bar inserted in hole?
298 Views, 6 Replies
10-17-2012 07:17 AM
Hello all.  I'm still new to inventor and a fresh face in the industry as I am still in school learning my mechanical design.  I'm trying to make this assembly flexible in that the bar will flex so the "s-clip" can hold the 2 handles together.  I read some of the forums about the scissors assembly in the autodesk folders and I can see it working in that assembly btu can't figure out how to make it apply to mine.  It is basically one of those camping grills that makes hot sandwiches or pies.  Please help!
Inventor 2013
JDMather
Message 2 of 7 (280 Views)
Re: Flexible constraints for bar inserted in hole?
10-17-2012 07:34 AM in reply to: sp1n1mbus
You need to make an arc with a really large radius and then control the radius.
Think of it this way - at some locations on the earth's surface it appears to us as though the earth is flat because the radius of curvature is so large that is seems flat to us.
Is there a logical reason why you want to make this Adaptive.
Seems like a lot of work for little gain.
On-screen or even in-hand it the flex would be almost un-noticable.
A more interesting problem might be to use FEA to show the flexing.  (Enviroments>FEA)
Attach the assembly here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
sp1n1mbus
Message 3 of 7 (266 Views)
10-17-2012 08:06 AM in reply to: JDMather
I'm not quite sure at all if it's necessary.  I've only been using inventor for 3 weeks using what little knowledge I have from my solidworks course.  Basically after I did all the parts and assembly while doin this internship, my boss tells me I have to draw all the packaging and arrange them in different ways into assembly files to show the best way for it to be shipped.  So since i need to have it lay in the box without the handles "poking" through the boxes I wanted to constrain it as if they were assembled as opposed to breaking the "insert" constraints from the cast pieces to the bars.
I attached my iam file if you could look at it and give me some advice.  Don't laugh please, I'm still a noob! :smileyhappy:
Inventor 2013
Valued Mentor
mpatchus
Message 4 of 7 (258 Views)
10-17-2012 08:08 AM in reply to: sp1n1mbus
You need to include the IPTs as well as the assembly.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
sp1n1mbus
Message 5 of 7 (253 Views)
10-17-2012 08:21 AM in reply to: mpatchus
Sorry. I forgot about that.
Inventor 2013
sp1n1mbus
Message 6 of 7 (252 Views)
10-17-2012 08:21 AM in reply to: sp1n1mbus
sp1n1mbus
Message 7 of 7 (250 Views)
10-17-2012 08:22 AM in reply to: sp1n1mbus
That's all of em. I couldn't add them all in one post I guess.
Inventor 2013
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
