Inventor Forum
Flat pattern a pipe curve: Is it possible?
5 REPLIES 5
1667 Views, 5 Replies
I want to flat pattern a pipe curve with 22,5º. I've made an open sketch and revolved it 22,5º. I converted it to sheet metal, add the correct thickness, selected the interior face, but i can't flat pattern the model.
What am i doing wrong? I will need to do a lot of these flat patterns, and i really don't know how to solve this issue, and i do a lot of round to square and cone flat patterns, i know the steps to take. In this case i'm lost.
Can someone help me please?
I'm using IV10 Professional - Build 272 - SP3a
Thanks in advance.
David
5 REPLIES 5
Generally, Inventor versions prior to version 2010 will not generate flat patterns that require material deformation.
How will you fabricate this 'pipe curve' ?
-Paul Cunningham
johnteng00
Are you sure you want to bend a flat sheet metal into the shape you have shown? It may be feasible if you split the "pipe" into two pieces, then you can bend them, and weld the two pieces together. If it is a closed pipe, it may be a different procedure, and you can put sand into the pipe and bend the pipe into the shape you want. Maybe your company has better manufacturing facilities. solid3dtech.com does provide tool to unfold developable/nondevelopable surface, you can try it.
This is a sheet-metal shape in IV2010 that flattens
using the new "Rolled" feature.
IV2010pro-suite
Dell 670 dual Xeon - 3.2
3gb memory,
SCSI320-15k rpm
XP-Pro, sp3
Quadro FX3400: Driver: 182.65
Direct3D
SpacePilot Rel V: 3.7.12 Dvr V: 6.7.11 Firmware 3.12
AVG
8.5
Are
johnteng00
we talked about the different problems, I can image how Inventor "unroll" the part you have shown: they just simplify the curved fillet surfaces. You can just extract the curved fillet surface alone and ask inventor to unroll. See what happens.
The curved section is just that, a rolled section.
Requires a profile to extrude/roll and a work axis.
InventorSuite 2010
Dell Precision 690
Dual Quad Core E5320
@ 1.86GHz
4Gb DDR SDRam - 667 Mhz, ECC
SAS 146Gb - 15k rpm
Quadro
FX3500 256Mb - Driver: 182.46 Bios: 5.71.22.55.08
Direct 3D
XP Pro
Sp3  3Gb/2800
Space Explorer USB, release: 3.7.12 driver 6.7.11 firmware
3.17
AVG 8.5
we
what happens.
