Inventor Forum
Fix this bug PLEASE
3 REPLIES 3
jletcher
333 Views, 3 Replies
Fix this bug PLEASE
I know this will not be fixed with an update and will not be fixed in 2015 and seeing this client will more than likely never update again because he is thinking of changing to another software that is for manufacturing and not a click click click and rendering software.
But think it should be addressed for others. He is on 2012 by the way.
Client would like to set a position view for a drawing to send to a client but the way he was doing it does not work in Inventor and should. I did get what he needed but again he should not have to call me up to just tell him it is a bug in Inventor.
 He has a constraint Rotation/Translation and an angle constraint he drives to move it. He wants a position view down and one up. Master being the down. When he goes to make the up he drives the angle constraint to move it up when he says OK the prompt pops up saying it will be saved as override as it should.
But when he changes it back to master it goes to the down position as it should. But when he clicks for the up position it does not go up to the height is should be at. It does move but not where it was saved at.
So I guess the bug would be position views do not work with Rotation/Translation constraints.
Here are some pics to enjoy...
Down:
After driving angle to move up:
Override clicking yes :
After click master and going back to position 1. Notice it did not move back to the saved position needed. Only moved about an inch.
 Someday Autodesk I hope will wake up. But I will not hold my breath.....
3 REPLIES 3
jletcher
in reply to: jletcher
johnsonshiue
James,
The behavior you described here does not sound right. But, I need the dataset in order to find out where the exact problem and what the next logical step is. Could you post it here or send it to me directly (johnson.shiue@autodesk.com)? I would like to take a look immediately and understand the issue better.
Many thanks!
Software Test Engineer
jletcher
in reply to: johnsonshiue
No longer at that clients office so I cannot get you the data set at this time not sure when I can.  Client only calls when he has issues like this one. He thought he was doing something wrong but even after changing a few things still an issue..
 It would take you no time to make up something to test..
