Hi, I've created a BOM of parts from a large assembly and it has an item just listed as pt.1. I have no idea what this is or how to find it. Any ideas please?
Solved by Cadmanto. Go to Solution.
If you RC on the parts list and select "Bill of Materials". Once that is open, select this part and there is an option to open it. Then maybe, once open you can trace back to where it is used and located.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
I am playing around with a similar idea, I want a master assembly where the BOM includes the sub-assemblies drawing titles. Ideally I would like some sort of link/hyperlink that would take me/the buyer straight to the drawing.
And ideally the whole thing as a PDF
I want one drawing referencing everything, 2d and 3d files. I have spent too much time hunting for drawings. (my own fault anyway I know). So I suppose a top-down workflow with a drawing at the top.
Another thought. Did you ever try using this search function at the top of the browser?
If it was a painful tooth that got removed, then your pain is gone, right? Or is it worse then before. Either way, just in time for turkey day.
As far as the browser, I guess I am confused, if it shows up in the BOM then I would think it would appear somewhere in the browser as well.
I did not read al the responses, so forgive me if this has already been covered.
