Inventor General
Active Member
mjterry34
Message 1 of 12 (182 Views)
Fillet
182 Views, 11 Replies
02-25-2014 07:10 AM
How can you do the bottom raduis? Overall part in 2" X 2.25"X 1" raduis is .5
Valued Contributor
VdVeek
Message 2 of 12 (171 Views)
Re: Fillet
02-25-2014 07:24 AM in reply to: mjterry34
If you can attach your ipt it's a lot easier for us to help.
Autodesk Inventor 2012 Certified Associate & Autodesk Inventor 2012 Certified Professional.
Active Member
mjterry34
Message 3 of 12 (164 Views)
Re: Fillet
02-25-2014 07:30 AM in reply to: VdVeek
Here is the file
Distinguished Mentor
JoAnn_Hogan
Message 4 of 12 (131 Views)
Re: Fillet
02-25-2014 10:37 AM in reply to: mjterry34
First of all, Your sketch should ALWAYS be fully constrained. It is not constraied at all.
Secondly, You have lines over each other, and very small gaps (Which would have been prevented if your sketch was constrained.
Third, It wouldnt do the fillet with that radius with all these gaps.
Please let me know if this helps
Jo (P.S follow me on twitter @JoAnn_Hogan)
If this post solved your issue please mark as solved and Kudos are always welcome =)
AutoCAD Certified Professional 2014 / Inventor Certified Professional 2014
JDMather
Message 5 of 12 (118 Views)
Re: Fillet
02-25-2014 11:10 AM in reply to: mjterry34
I found the part fairly easy to model in Inventor.
But there are several things I couldn't figure out -
1. Why didn't you use the Origin Center Point for symmetry?
2. How did you create perfect sketch arcs without dimensions (did you erase the dimensions for some reason)?
3. As already noted, why do you have lines overtop of lines?
Your original screen capture looks like it might be from SolidWorks.  Is that the case?  If so, can you zip and attach the original file here?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
mjterry34
Message 6 of 12 (115 Views)
Re: Fillet
02-25-2014 11:17 AM in reply to: JDMather
1. Why didn't you use the Origin Center Point for symmetry? I dont know, just start drawing. I am new to this
2. How did you create perfect sketch arcs without dimensions (did you erase the dimensions for some reason)? Yes, I erase them.
3. As already noted, why do you have lines overtop of lines? Did not know I had lines overtop of lines. How did you know that? Can you send me the part you made?
Active Member
mjterry34
Message 7 of 12 (112 Views)
Re: Fillet
02-25-2014 11:18 AM in reply to: JoAnn_Hogan
How you know I have very small gaps? I am new to this.
JDMather
Message 8 of 12 (104 Views)
Re: Fillet
02-25-2014 11:30 AM in reply to: mjterry34
Where are you getting the information for creating the geometry?  Do you have another file? A drawing?  Can you attach this information here?
I recommend you start here
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
JDMather
Message 9 of 12 (97 Views)
Re: Fillet
02-25-2014 11:36 AM in reply to: mjterry34
mjterry34 wrote:
 raduis is .5
 In the image all radii appear to be identical.
In your sketch 1 all radii are .25
In your sketch 2 you have radii .5 - where did this information come from when all radii in the original are the same?
Active Member
mjterry34
Message 10 of 12 (90 Views)
Re: Fillet
02-25-2014 11:44 AM in reply to: JDMather
No orignal drawing just a sample. somebody else did the 2 sketch 2 with .5 radii.  How did you draw the part?
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
