Inventor General
Member
ElectraGlide
Message 1 of 3 (548 Views)
Fillet weld not showing typical bitmap texture in Inventor 2013
548 Views, 2 Replies
05-31-2012 11:25 AM
Usually when creating a fillet weld it displays a texture of a wavy surface.  I can only get a smooth surface.  Is there a way to modify weld appearance to what I'm used to?
Member
ElectraGlide
Message 2 of 3 (538 Views)
Re: Fillet weld not showing typical bitmap texture in Inventor 2013
05-31-2012 12:15 PM in reply to: ElectraGlide
After playing around with Appearances for Welded Mild Steel, I discovered Inventor was trying to pull an image file called WeldCat.png from a bogus location in the project file.  No rhyme or reason for it except it was the last location I opened a document.  I found the actual image file in a folder under Autodesk Shared and redirected it.  Now, it seems to be okay, until the next time I need a texture and it comes up missing!
Product Support
Message 3 of 3 (514 Views)
06-08-2012 03:57 PM in reply to: ElectraGlide
Did you migrate your weldmen assembly before you added new weld beads?
I would also be interested to know where the "bogus" location was pointing at.
The weldcat0.png texture bitmap that is used in the weld materials gets installed by default in the following location
C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\1\Mats.
Do you have this folder on your machine and does it contain data?
Thanks.
Bob
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
