Inventor General
Active Member
Capsicum
Message 1 of 7 (2,800 Views)
File exchange between Rhino and inventor/revit
2800 Views, 6 Replies
10-26-2011 11:16 PM
Hi
Im no expert in Autodesk and i only use the civil 3d platform myself but we have several costumers using Inventor and Revit for their modeling and i have som quick questions.
We use Rhino and sometimes Sketchup for modeling scanpointclouds and need to deliver this model to Inventor and Revit, what exchange format is the most compatible for this ?
Employee
Message 2 of 7 (2,795 Views)
Re: File exchange between Rhino and inventor/revit
10-27-2011 12:04 AM in reply to: Capsicum
Hi Capslcum,
What's Inventor version your customer use ? Inventor can directly open the Rhino files with *.3dm (see attached image). Revit should also support Rhino file format *.3dm, if not, I suggest to use STEP or IGES neutral file format.
Kevin Li
Kevin-Hongyuan Li
Quality Assurance Team
Autodesk, Inc.
Active Member
Capsicum
Message 3 of 7 (2,791 Views)
10-27-2011 12:23 AM in reply to: KevinLi-Autodesk
Thanks for the informative reply :smileyhappy:
Distinguished Mentor
Message 4 of 7 (2,783 Views)
10-27-2011 06:10 AM in reply to: Capsicum
If memory serves, the Rhino translator was added as a bonus in 2010. It supports Rhino version 4 and maybe earlier versions.
Active Member
Capsicum
Message 5 of 7 (2,756 Views)
11-10-2011 10:45 PM in reply to: KevinLi-Autodesk
Hi
When i export a test model from Rhino i get several options on STEP and many options on IGES.  I have no idea what these options does, seems like different templates for different softwares/applications,    Does anyone knows what to select ?
Message 6 of 7 (2,748 Views)
11-11-2011 05:36 AM in reply to: Capsicum
Post a (preferably small) 3dm sample.
Active Member
Capsicum
Message 7 of 7 (2,726 Views)
11-16-2011 04:52 AM in reply to: Capsicum
Hey
My costumer is trying to import the files i sent him, but he doesnt quite know which buttons to press for the import, i am not a REVIT user myself so i cant be of much help.  Which function should he use to import the files mentioned above ?
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
