Just ordered one, but with Win2k...
I doubt that multithreading will do much good for IV (hopefully somebody
proofs this not true), as IV mostly stresses the floating point unit to the
max most of the time, and max is max, what can multithreading do more here?
The first syntetic benchmarks (3dmark2001SE) done show only the slight
performance gain of 9% due to the higher cpu clock. A test published by
Intel running Lightwave3D points out a "3 times better performance than a
1GHz cpu" - so that is clear?
As I understand things, this hyper threading may be good if you are running
several different apps simultanously.
Leo Laimer
Maschinen- und Fertigungstechnik
A-4820 Bad Ischl - Austria
"Dan Moyer" schrieb im Newsbeitrag
news:D731DAAB840E542E81907D276D1D7CCD@in.WebX.maYIadrTaRb...
> Somebody should test the new Intel P4 3.06GHz with "Hyper-Threading".
This
> allows muliti-threaded operating systems, like XP Professional to think
that
> it's dealing with dual CPUs. Inventor's hidden line removal routines are
> multi-threaded as are most of the better Open/GL graphics card drivers
(like
> nVidia). This means that they can take advantage of multi-processors,
> assuming you've installed your XP in it's multi-cpu configuration. I
would
> think that this setup would make a noticable difference in Inventor, at a
> much lower cost than dual Xeon's and the required special motherboard.
You
> have have have the latest Intel 850 chipsets on your motherboard to use
> Hyper-Threading.
> Dan Moyer
> "Dustin Conklin" wrote in message
> news:954ED537DBFCC52B15F8C9553E03BABE@in.WebX.maYIadrTaRb...
> > I will tell when I upgrade to my dual 2.4ghz with a gig of Ram from my
> dual
> > 750mhz the difference was amazing.
> > "Sean Dotson" wrote in message
> > news:4A721CF9982603C882B33DB19D5DE477@in.WebX.maYIadrTaRb...
> > > If Shakespeare were alive today he would have said:
> > > "The first thing we do, let's kill all the (IT professionals)." [Henry
> VI,
> > > Part 2]
> > > Seriously, look at my benchmark results on my site. While the program
> > only
> > > gives shades of gray between processors you can get an idea that most
> > people
> > > who are using P4 1GHz and above processors are running quite a bit
> faster
> > > than those with P3 sub 1GHz processors.
> > > Depends on what you are doing and how many parts in each assy. If you
> are
> > > doing small 30part assys then 800mHz will suffice. Anything more than
> > that
> > > and you really should look at upgrading.
> > > Sean Dotson, PE
> > > http://www.sdotson.com
> > > ...sleep is for the weak..
> > > "Bob MacGillivray" wrote in message
> > > news:BA1854A173668445EAF8A22284E6E8C0@in.WebX.maYIadrTaRb...
> > > > Normally I wouldn't even put this headline in this news group, but
the
> > > posts
> > > > provided by the readers of this headline really gives us a
perspective
> > on
> > > > where IV users are in relation to other commercial and gaming
software
> > > (s).
> > > > We need the hardware, but to justify the expense, we sometimes have
to
> > > > overcome IT personnel who feel that a 500 or 800 Mhz machine is good
> > > enough.
> > > > Sad day, but the price of hardware is still on a downward trend.
> > > > http://zdnet.com.com/2100-1103-965411.html
