Inventor Forum
Fastener Thread
29 REPLIES 29
Message 1 of 30
777 Views, 29 Replies
Fastener Thread
I just started using the fasteners in
INV 6 and the threads do not show up.
Also I tried a 1/4 socket head cap
screw and the body diameter was wrong.
What am I missing?
29 REPLIES 29
Message 21 of 30
Sorry Drew, that is incorrect...
This is just as easy in Iparts. You don't have to have the child already
built. When you choose replace all, don't choose a child, choose the
factory, you then can choose a new instance. If it's already built it'll
use the child, if it's not it'll create it and replace all instances of it
with the new child. Therefore you are using the iParts GUI and you don't
need to know filenames (well you need to know the factory name but if you
can't figure that out you don't need to be using iParts..)
Sean Dotson, PE
http://www.sdotson.com
...sleep is for the weak..
"Drew Fulford" wrote in message
news:B74179A98ABC36D31F3944EB4F78F188@in.WebX.maYIadrTaRb...
> Replace all only works if you've already built the child to replace them
> with. If not you need to build it first. Additionally you are by-passing
the
> iPart GUI interface in doing this therefore you need to know the filenames
> which you may or may not.
> - Drew
> Drew Fulford B.A.Sc. Systems Engineer
> Solid Caddgroup Inc. Burlington, Ontario
> Tel: (905)331-9670, Fax: (905)331-7280
> Corporate: http://www.solidcadcam.com/
> Member of the Autodesk Discussion Forum Moderator Program
> Visit my MCAD website @ http://www.mymcad.com/
> "Kent Keller" wrote in message
> news:EFEA64793BA5054FAAC896A6F2180512@in.WebX.maYIadrTaRb...
> > I agree.........
> > with both of you
> > For my paltry needs iParts are the only way to go, but I am sure if I
had
> > more purchased parts needs, I would welcome a well built Library of
parts.
> > Unfortunately as long as they are not able to be modified to individual
> > company's requirements they are about as useful as a Rev table that cant
> be
> > set up to a company's default settings.
> > Oh PS Wouldn't Replace all do what you ask below? Seems to work for
> me
> > the times I have had to use it. .
> > Kent Keller
> > http://www.MyMcad.com/KWiK/Mcad.htm
> > news:1250F8970E9491FB44DBE73D139CAE7D@in.WebX.maYIadrTaRb...
> > > Ok but try and replace 500 1" iPart bolts with 1-1/2" bolts in one
shot.
Message 22 of 30
Well now *I* know how to do that 😉
"Sean Dotson" wrote in message
news:24A352758B89C0495DDE49E3835E50DB@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
> the
filenames
> > - Drew
> > > I agree.........
> > > with both of you
> had
> parts.
individual
cant
> > be
for
> > me
> > > Kent Keller
> shot.
Message 23 of 30
This conversation suddenly makes more sense
Kent
news:8F9CE2E2F8FEF468047D2FCF327C297C@in.WebX.maYIadrTaRb...
Message 24 of 30
I meant you in the collective sense not you personally...
So Content-boy you got any other points I can shot down today
Sean Dotson, PE
already
it'll
it
don't
you
> > Sean Dotson, PE
them
by-passing
> > the
> filenames
> > > - Drew
> > > > I agree.........
> > > > with both of you
I
> > had
> > parts.
> individual
> cant
> > > be
> for
> > > me
> > > > Kent Keller
> > shot.
Message 25 of 30
Preferably a preset - but then I don't know how to achieve that with the
volume of parts that are involved. Personally, I only use Material,
Description, P/N and Vendor. Vendor being blank in most cases for screws
but filled in for other hardware such as bearings and gears.
But, one thing that would be necessary for fasteners at least is the
edibility to have multiple materials for the same parts - you know...
Stainless Screws along with Alloy Screws.
"Neil Munro" wrote in message
news:BF239B9DDA4BF75017B46416A18449D6@in.WebX.maYIadrTaRb...
> Almost. I have already seen a tool that enables you to set material and
> render style of library component occurrences on placement (and does so
> unobtrusively). I don't know when or even if it will be released for
general
> consumption, but the possibility is there. The ability to preset
properties,
> or set then on component placement seems to be the other currently
solvable
> problem (content creation will probably require more tools from Adesk).
> Would the ability to preset, or set on placement, a subset of properties
> such as vendor and part number be sufficient, or would all properties need
> to be available to make such a tool worthwhile?
> Neil
> "Ron Crain" wrote in message
> news:69BF2D8197090E41729DBB08DAEB0E43@in.WebX.maYIadrTaRb...
> > Did I fall asleep and magically Inventor Content is editable for
Material,
> > Vendor, Part numbers?
> > news:143CAC03037215A3D735C8065B7175B9@in.WebX.maYIadrTaRb...
> > > Some of the lookup & replace component functionality options in the
new
> > > content is appealing. Its stuff iParts cant do.
> > > I think iParts have their place but for real basic stuff, i think the
> > > content is earning a place. Sorry sean 🙂
Message 26 of 30
So, after all that... why do the
threads not show up?
And why is the diameter
wrong????
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #0000ff 2px solid; MARGIN-RIGHT: 0px">
in INV 6 and the threads do not show up.
What am I missing?
size=2>Thanks
Message 27 of 30
Try installing sp1
Cory McConnell
BJ Pipeline Inspection
"anton" wrote in message
news:181F9297CA3C9121C891B28571DBF10B@in.WebX.maYIadrTaRb...
> So, after all that... why do the threads not show up?
> And why is the diameter wrong????
news:98790775A4A99AC05A88CE7A2C2CF47D@in.WebX.maYIadrTaRb...
> I just started using the fasteners in INV 6 and the threads do not show
up.
> Also I tried a 1/4 socket head cap screw and the body diameter was
wrong.
> What am I missing?
> Thanks
Message 28 of 30
I did install SP 1...
any other ideas?
Try
installing sp1<g>
Cory McConnell
BJ Pipeline
Inspection
"anton" <
href="mailto:abullock@hotmail.com">abullock@hotmail.com
> wrote in
message
href="news:181F9297CA3C9121C891B28571DBF10B@in.WebX.maYIadrTaRb">news:181F9297CA3C9121C891B28571D...
> And why is the
diameter wrong????
>   "anton" <
> wrote in
message
href="news:98790775A4A99AC05A88CE7A2C2CF47D@in.WebX.maYIadrTaRb">news:98790775A4A99AC05A88CE7A2C2...
show
up.
wrong.
>   What am I
missing?
Message 29 of 30
Do you have "Show Reflections and Textures" checked
on Tools/Applications Options/Colors?
any other ideas?
Try
installing sp1<g>
Cory McConnell
BJ Pipeline
Inspection
"anton" <
> wrote in
message
href="news:181F9297CA3C9121C891B28571DBF10B@in.WebX.maYIadrTaRb">news:181F9297CA3C9121C891B2857...
> And why is the
diameter wrong????
>   "anton" <
> wrote in
message
href="news:98790775A4A99AC05A88CE7A2C2CF47D@in.WebX.maYIadrTaRb">news:98790775A4A99AC05A88CE7A2...
show
up.
wrong.
>   What am I
missing?
Message 30 of 30
No I am fresh out. I don't use the content library, so I am at a loss. (I
don't even have it activated)
Cory McConnell
news:D4944E9AEB2FFD557E46146153FA7168@in.WebX.maYIadrTaRb...
> any other ideas?
> "Cory McConnell" wrote in message
news:2BB1081BFE78E30FD823512778289EDD@in.WebX.maYIadrTaRb...
> Try installing sp1
> Cory McConnell
show
> up.
> wrong.
> > What am I missing?
> > Thanks
