Can anybody help me on this? I am trying to edit Family table as per my requirement. In the family table editor, the columns for " Sectional area, Moment of Inertia, Section modulus etc...." are available. These kind of properties have to update manually or there is any option available to generate autmatically ?
Please find the attached image for more clarity !!!
Are you making a new entry, and therefore you need to find the values?,
Try to either consult a steel supplier's spec sheet or use the cad software to interigate the values from the geometry from inside the cad software.
Not sure exactly the question you are asking.
Here's a decent website for the material characteristics of pretty much any material you could want.
Mechanical, physical and environmental properties of materials
http://www.matbase.com/index.php
Thats ok, But my question is, we can find out sectional area, moment of inertia etc by equations. Presently am using excel for calculating this equations and once i equated all, i copy that to the family table.
yesterday i found an option, For example i considered Sectional area(pipe), Right click on header > then select colum properties> there i can able to give expressions. I did all these and after that i am getting output in family table.But i found that the column for sectional area in now on red color and once i give apply and ok.Then in content center editor window i select the specific item the values for sectional area is shown as "0".
Hopes now u got a clear picture!!!! Please find the attached images foe more details.
