Inventor Forum
Failure to display visible pdf file
11 REPLIES 11
Message 1 of 12
rjkdk
709 Views, 11 Replies
For some reason I have not been able to generate a pdf file with visible lines fro the attached file. I will be very interested to learn the solution to this.
11 REPLIES 11
Message 2 of 12
mcgyvr
in reply to: rjkdk
Works just fine if you print directly to a PDF printer (like acrobat distiller, cutepdf,etc...)
Message 3 of 12
rjkdk
in reply to: rjkdk
Thanks for trying.  Does this mean I need to buy another program? Is there nothing in Inventor 10 that can be set up to do this task?
Message 4 of 12
blair
in reply to: rjkdk
Not sure with Inventor10 but with Inventor 2010 you can use the Export>PDF option.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 5 of 12
Cadmanto
in reply to: rjkdk
I know when we have had issues we use a program  called "dopdf" .
It seems to work for us.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 6 of 12
rjkdk
in reply to: Cadmanto
Oh dear Norton does not like this program so will not permit it to load!
Message 7 of 12
rjkdk
in reply to: blair
I have been using Inventor 2010 for years with no difficulty/ saving as a pdf.  This image seems to be unusual. It is an oversized drawing 34" x 214 inches intended as a full sized template.
Perhaps the size has some bearing on the failure to display lines.
The PDF preview indicates visible layers but nothing shows up on the field of the  drawing.
Message 8 of 12
blair
in reply to: rjkdk
Try changing the options in the Export>PFD from Standard to Hi-Quality or the DPI resolution.
Delta Tau Chi ΔΤΧ
Message 9 of 12
mcgyvr
in reply to: blair
short of playing around with all the Inventor pdf export options... try this (its free)
http://www.cutepdf.com/Products/CutePDF/writer.asp
Message 10 of 12
rjkdk
in reply to: rjkdk
HELLO,
Have yopu tried this on the attached file. I could not get a result.
Please try your solution and tell me what happens.
Message 11 of 12
rjkdk
in reply to: blair
Message 12 of 12
blair
in reply to: rjkdk
Without the related IAM file and all the IPT files that are required to open the IDW file it would be a waste of time to even download the IDW and try. If you are going to send a IDW or IAM file, use the Pack-and-Go to collect all the required files.
Delta Tau Chi ΔΤΧ
