I cannot create even the simplest cylinder. I get this message when I click OK in the Shaft Component Generator: "Failed to update component E:\Work Files\TECH\VT1\V1-7300-A\Design Accelerator\Shaft4.ipt. Failed to create shaft." My content center is available. It has round bar in it in inches. I have red column titles in the Nominal Diameter and Length columns. The values selectable in the Shaft Component Generator are metric.
Geoffrey Wheeler
AutoCAD Mechanical 2011 SP2, IV Pro 2011 64bit SP2, stand alone, Design Review 2018, DWG True View 2018, Inventor View // Win7 Ultimate SP1
ASUS P8H61-M LE, Intel i5-3450 @ 3.10 GHz, 8GB RAM // ATI AMD Radeon HD 6600 Series, 1GB RAM
