Inventor General
Distinguished Contributor
Message 1 of 4 (188 Views)
Failing to extract sketch as iFeature
188 Views, 3 Replies
03-07-2012 02:27 AM
I created the attached parametrized CF Flange iPart (one can change size, bored/blank, tapped/through, fixed/rotatable). I wanted to extract the cross-section sketches as iFeatures, so that I can reuse it also as sketches. I can extract the "Cross Section (Fixed)" sketch as an iFeature, but not "Cross Section (Rotatable)". I created this iPart file about half a year ago, and as far as I remember I created these two sketches in exactly the same way. Can somebody explain why it doesn't work?
Thank you very much
Danie
*Expert Elite*
Message 2 of 4 (181 Views)
Re: Failing to extract sketch as iFeature
03-07-2012 04:42 AM in reply to: barnadaniel
I didn't bother to try to figure out what doesn't work, but -
why isn't the origin at the center of rotation?
why repeat dimensions rather than use equal = constraints?
why sketch both cross-sections of a revolved profile?
don't use projected sketch geometry in these sketches (tie to the origin).
don't use user workplanes - use origin workplanes.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Message 3 of 4 (179 Views)
03-07-2012 04:49 AM in reply to: JDMather
Thanks for your comments.
"why isn't the origin at the center of rotation? don't use user workplanes - use origin workplanes! don't use projected geometry, tie to the origin"
The answer to these comments is that if I then want to extract anything from this file as an iFeature, which I can place anywhere in another part (the revolved body, or the sketch), it *must not* be constrained to the global coordinate system. This was discussed here: http://forums.autodesk.com/t5/Autodesk-Inventor/Reference-geometry-other-than-sketch-plane-for-iFeat...
"why repeat dimensions rather than use equal constraints?" - you are right.
*Expert Elite*
Message 4 of 4 (177 Views)
03-07-2012 05:07 AM in reply to: barnadaniel
The part should be created at the origin.
Coincident constraints can be deleted.
Maybe I haven't taken a long enough look at this part - why isn't it an iPart rather than an iFeature that you are after?
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
