Inventor Forum
Failed Installation aborted, Result=1603
12 REPLIES 12
Message 1 of 13
23203 Views, 12 Replies
(Inventor 2009 Pro)
Cant install Content Center or ADMS on a new computer with a fresh install of XP SP3 (go figure)
* Yes, I've searched these boards for "error 1603" and have done what most of them wanted to be done (except I dont believe changing the admin password to blank has anything to do with it)
* Using NOD32, its disabled, I made sure it will never ever ever even think about looking at port 80
* No firewall
* Logged in as an admin with full admin rights
* no previous copies of any Autodesk products installed (this is a fresh install people)
* Framework.net 2.0 and service packs installed
* Framework.net 3.0 and service packs installed
* Framework.net 3.5 installed
Here is the Setup Log:
2009/3/30:10:47:53 Admin ST5386 === Setup started on ST5386 by Admin ===
2009/3/30:10:48:31 Admin ST5386 === Setup ended ===
2009/3/30:10:48:30 Admin ST5386 === Setup started on ST5386 by Admin ===
2009/3/30:10:54:12 Admin ST5386 Install VBA (2627.01) Succeeded
2009/3/30:10:54:19 Admin ST5386 Install DirectX 9.0 Runtime Succeeded
2009/3/30:10:54:22 Admin ST5386 Install MSXML 6.0 Parser Succeeded
2009/3/30:10:54:25 Admin ST5386 Install MDAC 2.7 Succeeded
2009/3/30:10:54:32 Admin ST5386 Install Microsoft Visual C++ 2005 Redistributable Succeeded
2009/3/30:10:56:02 Admin ST5386 Install DWG TrueView 2009 Succeeded
2009/3/30:10:56:13 Admin ST5386 Install Microsoft WSE 3.0 Runtime Succeeded
2009/3/30:10:57:13 Admin ST5386 Install AOEMView 2009 Succeeded
2009/3/30:11:11:19 Admin ST5386 Install Autodesk Inventor Professional 2009 Succeeded
2009/3/30:11:12:14 Admin ST5386 Install Microsoft Visual C++ 2005 Redistributable Succeeded
2009/3/30:11:31:15 Admin ST5386 Install AutoCAD Mechanical 2009 Succeeded
2009/3/30:11:55:15 Admin ST5386 Install ADMS System Check Failed Installation aborted, Result=-1
2009/3/30:11:55:29 Admin ST5386 === Setup ended ===
2009/3/30:14:10:21 Admin ST5386 === Setup started on ST5386 by Admin ===
2009/3/30:14:10:55 Admin ST5386 === Setup ended ===
2009/3/30:14:10:54 Admin ST5386 === Setup started on ST5386 by Admin ===
2009/3/30:14:12:46 Admin ST5386 Install MSXML 6.0 Parser Succeeded
2009/3/30:14:13:20 Admin ST5386 Install ADMS System Check Succeeded
2009/3/30:14:14:36 Admin ST5386 Install Microsoft SQL Server 2005 Express(AUTODESKVAULT) Failed Installation aborted, Result=1603
* Attached is a picture of the FAIL
* Hardware:
Core i7 920
Intel X58 board
4GB of DDR3 PC10666
ATI 4870
S.O.S. again 😞
12 REPLIES 12
Message 2 of 13
I have no experience with NOD32, however, many AV programs
will still have processes running in th ebackground after disabling
them.
Here's some addl info that might help:
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
AIP 2008 SP3,
AIP 2009-SP1 PcCillin AV
HP zv5000  AMD64 2GB - Geforce Go 440, Driver:
.8185
XP Pro SP3, Windows XP Silver Theme
href="http://teknigroup.com">
size=2>http://teknigroup.com
Message 3 of 13
john.elliott
These products can not be installed on a substituted, compressed or a drive mounted on another drive. Edited by: john.elliott@autodesk.com on Mar 30, 2009 10:27 PM
Message 4 of 13
please attach the log file of Autodesk Date
Management Server 2009 Installer in %temp%.
try to install SQL 2005 directly, you can find it
in DVD2\Support\SqlExpress
Message 5 of 13
Dennis, Yes, disabling NOD32 doesn't remove it's process (ekrn.exe) and ekrn.exe is un-removable within the task manager. If I was to end process, it will start itself back up with a second, and I'm gona be in big trouble if I'm forced to uninstall anti-virus software to install Inventor.
John E, The harddrive is not substituted, compressed or mounted drive, just a 80gb sata2, NTFS format, and one partition.
Kevin, I couldn't find the log file your discribing. The log files I have are:
AcadmInv2009SWLInstall.log (file too big to attach)
AOEMView 2009 Setup.log (file too big to attach)
Autodesk Inventor Professional 2009 Setup.log (posted at top of page)
DWGVIEWRInstall.log (file too big to attach)
Inventor2009Install.log (file too big to attach)
I attempted to manualy install SQL 2005 from DVD2 and after it passed the 13 requirements (or so) it then failed.
MSXML6 = setup failed.
SQL Setup supprot files = setup finished
SQL Native Client = setup finished
SQL VSS Writer = setup finished
SQL Server Database Services = setup failed.
All of this....................... is so I can insert a screw in an assembly. 😞
Message 6 of 13
You will probably have to uninstall the antivirus to make the
install work. I have had to do this with Norton and AVG on extreme cases. You
should be able to re-install if you have the SN.
Expert
Expert.
AIP 2008 SP3,
.8185
href="http://teknigroup.com">http://teknigroup.com
Message 7 of 13
Dennis, thanks for the tips, but alas, I uninstalled the antivirus, uninstalled everything SQL related (and updates) within the add-remove programs, rebooted and still fails trying to install ADMS (talking to our tech support now)
Message 8 of 13
Very true. I had almost same problem on Vista 64 - all same symptoms except error was 1067 Finally abandon it and went to XP64. Some people suggested installing SQL 2008 instead of 2005. Never tried this.
Message 9 of 13
Well, looks like I cant even install Microsoft SQL server 2005 straight from their web site. Once I can get around this, Inventor should be all set.
Message 10 of 13
Hi, tomofnnh
It shows that the failure was caused by the SQL Server 2005 Express, but I'm not sure yet. Would you please try to copy the SQL Server 2005 Express Standalone installer to your local harddisk and check if you can install it successfully?
While you install SQL Server 2005 Express, please make sure to rename to SQL instance to "AutodeskVault". Of cause, please remember your sa password, which will be used to install the Inventor CC library.
If you can install the SQL Server 2005 Express successfully, then you can try to execute our Server installer.
Please let me know if you have any further question or problems.
Frank
Message 11 of 13
[Day 3]
Frank,
* I drag and dropped the SQL server 2005 setup from disk 2 of 4 and ran it from the harddrive, no luck.
* Downloaded SQL server 2005 express from microsoft itself, no luck. (see attached pic)
* Renamed the SQL instance to "AutodeskVault" and changed the "sa" password from default to "password1", no luck
* removed the admin and all user accounts from the PC
* removed all SQL related items within Add/remove programs....except MSXLM 6 refused to uninstall
Here is the last part of my SQLSetup0009_ST5386_MSXML 6_1.log file:
MSI (s) (84:94) [10:15:51:343]: Note: 1: 1729
MSI (s) (84:94) [10:15:51:343]: Product: MSXML 6 Service Pack 2 (KB954459) -- Configuration failed.
MSI (s) (84:94) [10:15:51:343]: Cleaning up uninstalled install packages, if any exist
MSI (s) (84:94) [10:15:51:343]: MainEngineThread is returning 1603
MSI (s) (84:60) [10:15:51:343]: Destroying RemoteAPI object.
MSI (s) (84:0C) [10:15:51:343]: Custom Action Manager thread ending.
=== Logging stopped: 4/1/2009 10:15:51 ===
MSI (c) (48:B8) [10:15:51:343]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (48:B8) [10:15:51:343]: MainEngineThread is returning 1603
=== Verbose logging stopped: 4/1/2009 10:15:51 ===
Message 12 of 13
AND THE ANSWER IS...................
MICROSOFT WINDOWS XP SERVICE PACK THREE
WOW huh.....
Uninstalled SP3, and now SQL installed, and CC works.
I get to keep my job!!!!!!!!
Message 13 of 13
MehmetDemirezen8197
Dear Sir/madam
When you install framework4.0, It will be fixed. here is the link for framework 4.0
http://www.microsoft.com/downloads/en/details.aspx?familyid=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&dis...
