Inventor Forum
Factory desing suite 2013 Inventor crashes
3 REPLIES 3
prem
345 Views, 3 Replies
Inventor crashes after starting a part file, the crashes almost immediate. I have installed service pack 1 and 2. I have attached crash logs for further reference.
using HP Workstation Laptop with I7 processor, 16GB Ram, Nvidia Quadro 3000m Graphics Card on Windows 7 64
Prem
Prem
Windows 7 64 Bit
16 Gigs of RAM
Intel I7
Nvdia Quadro 3000M
3 REPLIES 3
blair
in reply to: prem
Is this a new install? Has Inventor worked previously on this machine (existing install)?
You followed all the pre-requisites for the install:
1.) logged in with Admin privileges
2.) UAC slider set to lowest setting
3.) Current on all Windows SP's and Hot-fixes,
4.) .NET 4.0 installed on machine
5.) You have the current Microsoft certified graphics card drivers for your machine
6.) You have the SP1.1 for Inventor installed
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
prem
in reply to: blair
Got the solution
It has something to do with Autodesk Cloud Account signed in, once i sign out everything works fine
regards
Prem
Prem
Windows 7 64 Bit
16 Gigs of RAM
Intel I7
Nvdia Quadro 3000M
Yong.Jing
in reply to: prem
I have checked your Critical error Report from you. Some of the CER is contacted with known defect with ACM2013 which has been fixed in Sp1. Please patch it from below link.
AutoCAD Mechanical 2013 Service Pack 1
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20546317&linkID=9240898
Service Pack 1 for Factory Design Suite 2013
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19817524&linkID=15639656
Service Packs 2 for Factory Design Suite 2013
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20484229&linkID=15639656
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
